this is just me thinking, but if the flat tappet lifters wern't turning with synthetic oil due to the fact that the oil was too slipery, then how was it wearing the cams out, if it can't get enough contact to turn a lubed lifter, where did the wear come from to whipe a lobe, i think it is a bunch of BS personaly, and as an aircraft mechanic working for the military, we use synthetic in turbine engines for as long as it doesn't get contaminated by metal, we NEVER do an oil change, no such thing unless something lets go, the only real reason to change the oil in anything is for 3 reasons, contamination from some source, oil molecule breakdown caused by oil shear in the pumping section, or lastley by oil breakdown by heat, and in the breakdown catigory synth is superior in every way compared to mineral based oils which is why the oil change intervil is extendd in cars with its use, and oil contamination in stock cars is minimal due to percision fuel control and tune, but in older cars or those that have been modified, the interval of oil changes is based on the rate of contamination which is uneffected by oil type if the sole source of contamination is combustion byproducts, personally i run my cars rich to stay safe but i change the oil after any racing event or 2,000 miles. i think that if synth oil was causing a problem it would of been picked up by now with all the flat tappet cams in the world, but that just me.
Grant
