t-70 P-trim 4 Bolt turbo and DP.
boostingbuick
Going to be buried in this.
My Schwitzer-Borg and Warner turbo is for sale since I am upgrading. Its a 70mm 4-bolt turbo. The compresser has a 3 inch inlet and a 2 1/2 outlet. The exhaust side is a P-trim with a .69 a/r on center housing. Rebuilt less than 2,000 miles ago. Has little shaft play and no thrust play. This a NON roller bearing turbo. This will also come with the matching DP. Its mild steal. Has surface rust but very solid. Fittings not included.
I have gone 10.90's at 128 with turbo on pump gas.
$750 for both parts.
When I get home. I have a new tall tiped q trim Turbine wheel that will go with the sale. Unknown to the cost of install. I will post pics of it as well.
Here the DP and the wheel.
I also have a Deltagate for someone looking to convert to this four bolt. I have the new one on its way, so this one needs a new home.
