six slinger
- Jul 13, 2007
how much lighter is a t/a block compared to a stock block,and a staged block. thanks guys
SignUp Now!I just weighed one and it was 104.5 lbs with the mains and fasteners bolted up and un-touched sleeves. If it were bored to 4.020-4.060 it would be considerably lighter. 109's are 115-120 lbs the same way with a 3.8 bore. An S2 is around 140 lbs depending on bore size and main configuration.
How far can they be bored? I have heard through the grapevine that you can't even go to 4.00 in.
Weight of the TA alum block is about the same as a stock 109 block.:smile:
Mine is 4.005", the sleeves are believed to be 4.100" od Darton's GB
