T66 or PT67GTQ
TURBOV6
"SECRET PARTS"
Staff member
This two turbos are pretty much the same in perfromance but the 67 has a slight bigger wheel but the T66 has BB. Is the PT67GTQ much better over the T66?
Also the T66 requires a less stall
I would not get a GTQ for a car that will be mostly street driven. For mostly a track car I would jump to a 70 GTQ
Especially on a 231 your going to need at the min a 3500stall
well, Turbonetics can recommend what they want...I don't think you would be happy with a 2800 stall converter (particularly a 12" one)
3400 9" minimum
3000 stall with a T66 ball bearing.
Scott GN1270 ran one fine for two years on his car.
One year stock motor one year ported heads and cam.
Same stall, 9" is a good idea.
3200's are easily streetable as well, no need to ever go higher with BB's. ;)
The 66BB is an awsome street turbo, as well as a mid 10 second turbo at the track, of course with the correct supporting upgrades. We use them with a 3000-3200 stall 9.5 convertor, works great with a .63 exhaust housing.
The difference in flow over the 2 turbos (67GTP and T66BB) is very slight. The 67 is much more efficient at lower boost pressures. The 67 does not need to be boosted as high as the 66 to get the same power out of it.
If you get the 67GTP, you will be able to spool it better than the 67Q with lower stall. The 67GTP is closer in comparison to the T66BB. The 67GTQ flows a lot more exhaust and will make a lot more power, but it will take more stall to get it going.
If you do not mind higher stall, the GTQ is not that bad of an option, especially considering the difference in price. If you get the 67GTP, the retail price is $755.
It is up to you in the long run.
Re: Re: T66 or PT67GTQ
The PT67GTQ on precison's site is like $1100
:confused: Is this 67GTP a BIG SHAFT or SMALL SHAFT Turbo for $755.00?????????
BTW Who is selling 67GTP TR Turbos for $755.00 small or large shaft????
t66
if you decid to go with a 66 i'm selling a top o the line true garrett t66 from honeywell here are the specs..
P trim
large shaft
compressor housing ar.70 m240
exhaust housing ar.69
four bolt flanges on exhaust external waste gate.
four inch inlet for the compressor
boost up 40 psi
it is brand new.. it has a superstrong billitt backing plate that will not flex.
original cost just under $1400
will part with for $1000 obo or trade of equal value
here is the compressor map
http://www.turbocalculator.com/compressor-maps/t66.jpg
