TA-49a Turbo and Ported Heads
marvin's gn
Banned
Turbo is a TA-49a that is used and has about 5000 miles on it. I'm upgrading everything in my build and no longer need it. The turbo is in good shape and was working fine when I pulled it off the car. There's minimal up and down movement and no in and out movement. Looking to get to get 500.00 or best reasonable offer.
Also have a set of P&P'd heads that have 1.77/1.50 Ferrea Valves and flow 194cfm from .300 to .550 lift on the intake and 152cfm @ .550 lift. Flow sheet will go with the heads. These heads have no miles on them. Was planning on using them on my build but went with the GN1 head instead. They have Poston's high rev springs in them with the hardened locks. Would like to see 800.00 for the heads.
If this add looks familiar....it's because my brother (LIL QIK) posted them for me. But now I'm on the board as well. So I'm putting the add in my name for ease of contact info. You can either PM me or email me.
Thanks....
turbo
what else is needed to bolt on to a factory 87 t?
Not sure which one you mean....but both the heads and turbo will bolt right on to the 87 T-Type. Nothing else is needed.
Quick question: does the turbo have a Garrett .63 a/r housing or a Precision housing? Thanks for your help!
Thanks....
THE HEADS HAVE BEEN RELISTED DO TO INCORRECT INFO IN THIS AD, HAS BEEN FIXED THANKS.
hey Marvin,got the turbo and other parts(thank you,thank you)runs great!!!!! Gary.
