TA Aluminum Block Motor
tom robison
ALL UP IN THEM GUTZ
I am selling the TA blocked stage 2 that i built over this past winter. Motor did 851 hp at the tire in april. Motor has 0 street miles and 40-50 low 10, high 9 second passes on it. I have possibly sold my car as a roller and think I am ready to sell everything else and move on to diffrent things. Here is what the motor is.
-Ta oncenter 3.90 block
-3.625 narrow journel cat crank std/std.
-6.5 childs and alberts rods cut to fit narrow journal crank.
-King main, rod and cam bearings
-3.90 9-1 venolia pistons w/ .927x.225 pins
-.577/.571 248/242 comp cams solid roller
-Ta cam nose hardware w/ rollmaster timing chain
-crower solid roller lifters
-smith brothers 5/15 pushrods
-Ported M&A heads w/ shaft mounted T&D roller rockers
-Champion oncenter intake w/ 70mm throttle body and 160lbs injecters
-BMS crank hub and JW flywheel
-DLS external oil pump
-CAS aluminum oil pan
-electric water pump
All machine work was done by performance engineering in ross ohio and assembly was done by myself. Motor is still in the car and car be heard. I live 40 min west of cincinnati if you would like to come and take alook. I am asking $12,500.00 for what I have listed. I perfer not to ship. You can reach me at 513-218-4764 or pm.
Also for extra I have a very nice set of atr headers w/ a new 44mm tial gate and a almost new 76/75 percision turbo for 2500.00
Thanks Tom Robison
