Ta block build?
Its just like any other new block, the bores are rough machined to the minimum bore size, all the clearances will need to be checked and machined to specs. Though I do think the deck is finished. I'm pretty sure, Nick back me up here.................
The TA block does need to be surfaced AFTER the liners are seated.:smile:
We do lots of after market and alum blocks and ALL need to be finished machined. Even the new [when they were available!] factory replacement Buick blocks required final machining.
"The TA block does need to be surfaced AFTER the liners are seated"
Nick can you explain this please ?
Also the stock type motor mounts dont work ?
Go to TA Performance's site. You can download the latest block instruction sheet.
