ThisDo you have a flex pipe in the down pipe or exhaust? Maybe the system is too rigid and twisting found the weakest spots?
SignUp Now!ThisDo you have a flex pipe in the down pipe or exhaust? Maybe the system is too rigid and twisting found the weakest spots?
There has to be some give in the exhaust post turbo somewhere or it will pull on the exhaust manifolds as it torques over.
What should be done to make sure this does not happen ? Looking for suggestions before I install my new exhaust system.
So what did you do cut the center out of a test pipe and put a flex pipe in ?
........ I also found the front two header bolts had come loose and I mean I screwed them out with my fingers. Took it off, tiged it and made sure all bolts were damn tight and no problems since. I might ad mine are on Champion iron heads and fit perfect.
Mike, it is a little more time-consuming, but especially with alum heads, I have found a stud with a flange nut will NOT loosen like bolts tend to do!
If you use long set screws, they will be easy to install and remove. I always use copper gaskets with alum heads, and only need one re-torque after a heat cycle or 2.
