TA49, SLIC and Other New & Used Parts
RossGN
Sold the GN and don't see having another until we build another garage, so won't be needing this stuff. Parts are used unless specified otherwise. Prices do not inc shipping. Paypal preferred. PRICES ARE FIRM - If it doesn't sell, may adjust prices in a week or two.
TA49 turbo -0- miles since rebuild by PTE - .63 exh. housing - includes billet inlet bell...............$575
Adj. Wastgate Actuator.......................................$ 45
New turbo drain pipe w/gasket..............................$ 60
New front frame braces.......................................$ 38
New rear seat frame brace...................................$ 62
Nw Kirban "Mystery Theft Deterrant.......................$ 20
Ratcheting engine tie down..................................$ 30
Driveshaft loop..................................................$ 25
TT alky chip......................................................$ 25
Reman MAF - bought from board member but never tested...no guarantees...$25.00
Stock location intercooler - dings and dents - mfg unkown - works fine......drivers side mounting hole stripped out, so retapped for larger bolt - this will require that you enlarge the bolt hole on your intercooler bracket.....................$275.00
***************Earliest day I can ship will be Tues 6/28*************************
More pics
More pics
Slic
does the TA49 have a garrett or precision exhaust housing - i cannot tell from the pics.
what are the specs for the TT 5.7 alcohol chip - for a stock turbo or TA49 turbo? 42lb injectors and ?
Front braces, rear seat braces and DS loop sold.
Turbo has Precision housing.
TT chip says "TT 5.7 6526 42# Alcohol 23 deg - 21 deg 23-25 psi"
Sorry i'm so dim. what does "6526" mean? is 6526 the turbo that this TT chip was programmed for? if not, what turbo did you use with this chip? thx.
ta 49
hello does the turbo have the garret or precision housing looking for one with the garret housing thanks
Ok...back home with internet service. I think I've sorted and replied to the PMs.
TA49, wastegate actuator, theft deterrent, and SLIC still available. Prices are now OBO.
Also have new Kirban heavy duty valve springs $35 plus shipping.
