TAI Class for 2007 BG Nationals
This class needs to be kept as K.I.S.S as possible.
pump gas w/ 10 gallon minimum
alcohol/meth injection single or dual sprayers
No NOS
109 block
minimum weight requirement 3550 lbs w/ driver
DOT tires of some sort...max sidewall desiganted width of 10.5"
full exhaust
current registration and insurance
8445 or TTA equivelant heads
The above are the "must haves", all else is open.
We did it last year this way,lets just get MORE CARS!!!!!!!!!!!!!!!!
I feel that the flavor of the Alky class shoud be streetable cars & I agree that you will never get everyone to agree with the rules. So make the rules very simple, NO rules. If Mr. X thinks his 5,000 rpm converter & overheating external fuel pumps will work on the 25 mile cruise that's great but no jump starting the car, no golf carts dragging it around etc. You have 3 passes to average together so go set the world on fire. This will also Give the guys with the great running 11 & 12 sec pump gas cars something to shoot for & showcase there combo's also. Something for everyone & i bet you would get a good car count, something that's missing in a lot of the buick classes. I've never run alky but would certainly buy a kit and try it to run in a True Street format. I'm sure i can get it to run OK?? in 6 months.
Last year we had one car we didnt let run. It was a 69 Camaro weighed 3200-3300, nitrous, and a 5 gallon fuel cell. I didnt car bout the nitrous, the weight and inability to fit the 10 gallons did. So there are situations that the playing field needs to be level'd.
Just like the Hybrids.. would it be fair to allow a 2700 lb car with a Buick engine? The other is to allow 4.1's non-stage. This is why some minimal rules are needed.
I agree Julio, there needs to be a minimum weight that's indicative of a TR or TTA that's not all cut up with carbon fiber this and fiberglass that. It must be able to hold an amount of fuel that one could go for a cruise with and not have to stop every 50 miles to refuel. If you care to sit on a t-brake at the line and heat the tranny up...who cares! Lastly, if it started as a production 3.8 liter motor (109), no matter how many over bores you have done...again, who cares.
I will have my new ride in this class next year...prolly not very competitive, but I'll be there. Once we finish my dad's new motor...that will be a different story:)
Just like the Hybrids.. would it be fair to allow a 2700 lb car with a Buick engine? .
ohhhhh..here we go :biggrin: I am leaving the RX7 for the hybrid class ..ummmm Melissa doesn't want to drag 2 cars down so guess whose car is goin ??:redface: :biggrin: ok came up with more rules
car must be registered
state inspection sticker if your state has them
NO 2700# cars :eek:
Drag radials that have tread
:p
Drudging up a old post, Do we have rules for this yet :confused:
I may give it a shot (No Grumpy I haven't done the valve springs yet)
Dude we're on 2008 rules look on the top of the alcky section!!
yes the rules are posted!!!
thanks JD
Where all getting OLD!!!!!!!!
glad you found what you where looking for.
thanks JD
thanks JD
Speak for yourself...I get younger every day! You going to be in BG this year? When are you guys going to be there...I assume Motel V6 this year???
Glad to hear your not getting OLDER!!!!!!!!!!!
will be going but not doing Motel V 6
probably staying at the camp grounds
give me a call and well catch up
thanks JD
