Pittsburghkid
Displacement Replacement.
- Mar 22, 2009
So to start i have an 84. I wanted a thrid brake light so I got an 86-87 tail light harness and third brake light assembly and hooked them up. First the original harness didn't have the second pigtail with the single light brown wire hooked up (why I don't know) so when i put the new harness in I connected that pigtail. So i hit the brakes and all the necessary lights light up except the third brake light. I tried another bulb and the same result. Now the pigtail from the tail light harness has a light blue and black wire on either end and a brown wire in the middle however the harness for the third brake light assembly only has the black and light blue wire one either end and not the brown wire in the middle. So my question is, is the third brake light not working because of the missing wire in the middle and if so why is it there on one harness and not the other? And why would the part of the harness with the single light brown wire not be hooked up previously. BTW the taillights and marker lights also aren't working (brake lights work) even after checking all fuses but that's a problem for another day but if you have an answer for that also I'm willing to listen. Thanks
