For some reason my stage 2 is running rich (approx 10.75a/r at idle) I have 83# injectors, fuel pressure is at 34# with vac.line attached, vacuum is 18 inches, timing is 38 degrees (idle), voltage is 13.5 and new plugs (old plugs showed a rich condition along with burning eyes). Checked the coil resistance and the spark plug wires (all were in the 120 ohm range, coil was <11 ohms). With the engine at operating temp. and the FAST (batch unit) in closed loop with the target a/r set at 13.5, I am reading 11.7 and -25% correction. The fuel map numbers that it idles at are at 26- 27 and if I try to lower these, the engine starts "roll" and then dies and the correction still reads -25% with the a/r moving up to 12.3 (stange that the engine does not want to run when lowering these numbers). I will pull the injectors and have them tested next week. Any other suggestions? I think that I have all the enrichments set at zero but if someone has a quick review of the enrichments that I should check, that would be heplful. I had also tried to run in open loop with the same settings and the a/r was 10.78.
Thanks,
Jeff
Thanks,
Jeff
