turbonut85
Rarely used member
- Apr 11, 2008
Alright guys...after countless searches....I cant come up with a somewhat clear-cut target AFR reading I should look for on the Powrlogger through my LM-1 WB....
I am chasing some knock in my new setup...and I cat nail down whether its rich knock, timing, false, or what....I seem to be getting conflicting readings between the WB and NB o2s....WB says 11.9-12.0, and the NB says .847....? Problem is, the WB is used, and this is the first time I've run one, so I'm #1 not sure if it works correctly, and #2, not sure what the reading should be?? ...or maybe the E85 has fouled the denso NB??
Here is the setup:
4.1 production block
ported GN1s
champion intake
reds double pump
120lb injectors
LT1 MAF
and a queer little hot air turbo.......yes, you read that right.....HOT AIR.
any input is appreciated!!!!! ---Keith
Here is the setup:
ported GN1s
champion intake
reds double pump
120lb injectors
LT1 MAF
