fastblackracing
 - Apr 7, 2009
Also there is a way when you rotate the engine most of the lifters are down when you tighten the rocker mounts so that the amount you have to pull the shaft mounts down is less.  The six mark bolts are referred to as grade 8, A 3 mark would be grade 5 and no marks a grade 2 or peanut butter
. METRICS are classed by  8.8, 10.9 and 12.9 these are the common ones.  metric 8.8 =usa grade 5, 10.9 is close to usa grade 8.  I know you did not ask this but thought I would share it.
