I agree 100% with Postal in that the TE44 to TE45a/63 is a dang good jump in performance...great top end charge! I had a TE44 with a stock TTA converter and it was fine on the street but gave me a tad bit of grief comming onto boost (10-15+ psi) on the line (even on a T brake). I had Eric Marshall make a bunch of fueling changes down low to help expedite the boost spooling and it helped, but still wasn't fast enough to bracket race with and be consistant. When I went to the 45a I also changed the converter to the unit in my sig and absolutely love the spool both on the track and street! The 45a pulls much harder in the higher rpm range but is tame enough to be a killer on the street. The 45a is also a big shaft turbo which gives it more durability over the 44 which is also a good thing. I've also run a TE60 and TE63-1 with good results...just so long as you have enough stall to complement them. That brings me to my last point in that, with anything combo, it's all about combatability...how well do all of the "parts" complement one another. Example, when I first got my TTA it was about 99.9% stock. I dropped a chip in it that my buddy Bryan W. had and it picked the car up a BUNCH. That same chip in his pop's TR slowed it down a bunch...complementing I say not. What works for 1 car may not work with another, it's all in the combo and state of tune. I think your on the right path just so long as you take the time to dial that new turbo in with the rest of the parts....good luck to ya!
