Okay...here we go!
Man...slap that TE60 on there and have at it for a while. Worst case, you'll complain about it being "laggy" with the stock converter. Then you'll either think about, or put in a looser converter (because that's what everyone is going to say) and it'll pickup a little, and you'll think that was the problem. When actually you moved the RPM's up, which increased the flow! But once you put heads on the car, then things will really start to happen and you'll say "I should have done this a long time ago"...which is where you are right now.
Every car is different and I (for one) had good results with a TE60/TE61 with stock heads and believe it not...stock cam and converter. True, the TE60 (without heads or converter) did not spool like the stocker, but I did run low 11's like that! Once I put heads on it, it was a totally different car.
It's just my 2-cents worth and I'm sticking to it!
-Bobby
