SignUp Now!Great pics, wish I could build my own engine..![]()
Got the shortblock finished yesterday, 24 ft/lbs "breakaway" torque to rotate it. Put my RJC headgaskets on today, I'm thinking these are a step up from the old (no longer available) stacked GM shim gaskets! The sili-goop also went on my studs as well as the gaskets. Jace's torquing procedure is pretty intense, go to 50# in 10# increments then to 85# in 5# increments. One reason to be glad there are only 8 bolts per side!
what silicone are you using on those headgaskets? i am switching my ported heads to another motor,and having trouble finding the GE 1200 in the purple tube that was used the first time.
The tube that came with Jace's kit shows "GE SSG4000 UltraGlaze". Pretty long cure time, so no hurry on the assembly...
how long is the cure time? i'm in no hurry just askin
Hours, at least. Definitely sets firm overnight though...
Dont spend all of that 401k :biggrin:
Hey Russ! I'll be happy to dedicate a day to the cause. Just let me know. 409/225-7993. Joel
It's alive?
Wow, that was quick. LOL
I miss clowning around in the garage with you guys. Let me know when the work day will be, and I’ll try to beat down my kids (and wife) enough to slide out the door. I still feel a level of guilt, namely because I was in the passenger seat when it took a poo-poo.![]()
Still looks pretty good cleaned up! I had to look back through my build sheets to see that it's first drive was 01-10-2003...
Cool little truck,what does it say on the hood bulge?
Looks good! I want to do a s10 build myself someday but I have to have a ext cab. :biggrin:
Make sure the same problem doesn't get this motor.![]()
