Terry houston steel 3" down pipe
Bweavy
Car Hoarder
I have a bunch of stuff like this laying around & just tired of moving it every few months. Pipe has surface rust. No major dings or dents. Factory end has not been cut off. It would be a great canidate to get blasted then ceramic coated. Or just on a budget this is a lot less expensive then a stainless unit. $250 or best offer.
I'll be going thru the shop & getting a lot of old used performance & stock stuff up here shortly.
Would you go $225 shipped? if so pm me your pymt info and ill get it out to you. Thanks
Paypal $$ sent to you. Thanks
BTW...do you happen to still have the test/dump pipe for the downpipe?
I do not have the one that came with it. If you get the down pipe mounted up I can get you any length you need. We can build test & dump pipes in house. Once I hear back we can get you an exact length. I can gamble & toss in one I think would work for $30.00
I received pay pal & this will ship today.
Let me know on the test pipe.
If you have a test pipe with a dump that'll fit. I'll take it. I believe the TH dump pipes were about 14" if i recall. If the pipe is longer than 14" it shouldnt be too much of problem as longer as i have room on the side were it slides over the downpipe to cut it down a bit.
The test pipes & dump pipes for our down pipes are 12.5"
I have a used one back there that is 13.5" I think it was built for a TH that we had in here before we realized that some one had cut the end of that cars DP off.
Now that I have that second cup of coffee in me I remember that TH's were 13.5. I have a test pipe set up ready 13.5" for $30.00. Now it isn't a dump pipe it is a straight test. I can build you a new 14" dump pipe but it will not be $30.00.
Thanks for the quick reply backs. Just send off the downpipe for now till i decide what route im going to go with the other pipe. Really i only needed the dump pipe instead of the straight to open it up around the house to piss off my neighbors :D
When your ready we will set you up with a motorized dump. :biggrin:
You will ship today .
