Hi folks,
I've recently developed a rear suspension problem-- DS wheel hopping under launch at the strip.
I checked out the suspension components and noticed that I can move the DS rear upper control arm side to side (just a little 1/8" or less) at the top connection and that the nut & bolt would rotate with little effort. Everything is solid on the passenger side.
BUT the nut is thoroughly rusted to the bolt and I'm wondering if the change in the launch behavior is caused by the bushing finally going bad enough to make a problem.
Assuming that I can break the nut loose (many soakings of penetrating oil haven't helped), do folks think bringing it to torque will help w/o replacing the bushing? I for one can't think how the nut could have both recently loosened and then gotten rusted to the bolt.
Any guidance on telling a bad bushing from an old, but good one? Other ideas?
thanks,
Scott
thanks,
Scott
