Ms. FastNasty
- Oct 29, 2008
kirban 2 cents worth
fastnasty trunk ID label
Its one of the early 1986 style with the lamination over the label. As it has been pointed out earlier in this thread some 1986s did not get this lamination over the label. With that in mind, I assume you have an early production date? (What date appears on your door jamb?
You got VD6 and VD7 which is good lite weight bumper supports. Also VK3 is the front license plate bracket probably car originally sold in state requiring front license plates, posi rear G80, GN code WE2 shows up,
IN 1986 5 radio options you got the top of the line UX1 unit, was $494.00
UW4 concert sound option in the doors, $95 option, CC1 t Tops $850 deal, they should be the locking style may not be if its an early one ( going by memory)
B34 and B35 was the good front and rear carpet savers, you got factory door edge guards B91, but no body side molding, You got power door locks and optional power trunk release. Button should be in glove box attached to upper lip.
T63 the cheap headlite buzzer $16 option,
A RARE OPTION T82 twillight sentinel feature a $57 option! power drivers seat. WG1....
These are the main ones. You have a pretty heavy example especially being a GN with 30lb wheels on each corner but lite weight bumper supports.
The twilite sentinel is very rare. Not something many performance owners went for in a turbo buick. More of a Caddy luxury feature.
At 85 codes its a fairly loaded example.
The printing is lite but if the code is correct C68 you got the touch climate control option that was not offered in 1987 models. Advise if you have this option?
Any errors I apologize its because printing is hard to see on my end. Your car was pretty expensive. If I had to guess $17,900 to $18,300 radio and T-Tops being two big options...
Comments welcome
kirbanperformance.com
denniskirban@yahoo.com
If you have not posted your trunk ID label yet this is the thread to post it. We will tell you some of the highlights about it.
Going by memory this may be the first trunk ID label that has been posted in this thread, showing the twil light sentinel option.
Car was made in January 1986 and you are pretty much spot on with everything you're saying. The car does have the touch climate control, twilight sentinel, locking T-Tops, concert sound, digital dash, power drivers seat, and that annoying light buzzer. Have all the paper work from when my dad bought it new (along with the speeding tickets), looks like he financed $16,177.35. Glad to know where my car sits on the rarity scale...I guess 91 codes isn't bad at all! I wonder thought, what options were available that are NOT on my car...seems from previous posts there would only be a handful of them.
