Thermostat ?
turbobooster
Planning on Replacing thermostat but not sure Which one to go with I looked up on autozones website and there are about 7 different ones which part number are u guys using on ur cars ? What is recommended ?
Robertshaw all brass balanced flow
MR GASKET HAS THE ALL BRASS 54 MM unit which is a robershaw, THESE ARE BEST !
CHECK OUT ON INTERNET AND JEGS AND SUMMIT CATALOG, ALSO THE FLOWKOOLER 1621 water pump which is a modified standard pump flows better especially at lower RPMS and uses less HP at higher RPMS!
