Hi everyone,
I'm doing a 86 3.8 N/A build and am looking for a bit more performance. I'm trying to get 200hp and 250 tq out of this engine without boosting it. BTW this is an abandoned project that I inherited.
Here is what I'm working with:
- rebuild block 20 over pistons; 8.5 CR
- 4.1 intake with q-jet carb
- dual header exhaust
- mild porting done
The cam that I got is a Melling SBC-12. Brand new with lifters. This is the specks:
Cam Style: Hydraulic flat tappet
Intake Duration at 050 inch Lift: 180
Exhaust Duration at 050 inch Lift: 194
Duration at 050 inch Lift: 180 int./194 exh.
Advertised Intake Duration: 251
Advertised Exhaust Duration: 280
Advertised Duration: 251 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.359 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.384 in.
Valve Lift with Factory Rocker Arm Ratio: 0.359 int./0.384 exh. lift
Lobe Separation (degrees): 104
So ... does this cam have what it takes to get me to my goal or shoud I start looking for something better? I'm more concerned with the TQ number then with the HP #'s.
Thanks for any advice,
Al.
- mild porting done
Al.
