spoke with the machine shop. Which I want to make people aware. AND, I am not trying to slam any business. However, If I feel I was done wrong....and can help someone else... I will "whistle blow."
Barker performance and Machine, owensville ohio 513-724-3288
He talked with me this morning.
* Brought out the blue print.
1. Heads torqued to 75lb with moly. Claims this is what the ARP spec sheet calls for. WRONG, albeit only 5lb...but the instructions say 80.
2. He uses copper spray on everything. Motors that are full blown 2500 hp running 50lb boost, no issues with copper spray. Yet....cometic says not to use it I guess he needs to do R & D for these MFG
3. 60-65lb did not make my head gasket blow. It was a lean condition, (which could be possible) but the smoking gun is the improper installation process.
So, He left me high and dry again. I wont get too entirely off the topic about how he installed standard main bearings in this build and the oil pressure was shit, changed them to .001...issue solved. But then as well....he blamed it on my oil pump this March. I guess now that I have 20psi hot idle I now have is just a fluke?
I asked for 50$ worth of gaskets....just as a ways of saying...I am not too entirely sure what happened, but I am willing to work with you.....NOPE!
So.... burned???? yes. Learned??? yes.
I needed to vent, thanks for your ears!! lol!!
Turbobitt, I would not hesitate (which I am not) to use cometics again. Even if I had to pay for them. I feel the onus was on improper installation. I feel they do enough research and testing to do well with a mild engine as mine.
Jerryl. Yes I agree. They are forking out 275$ worth of gaskets for free....no issue. That in my personal opinion is listening and working with a customer in need. I do have some pull...yes. Any distributor that can represent their customer would have the same result...IMO. Also, I have never recorded a KR, so we are good there. Pistons, walls, plugs all looked good.
TruboBuRick, I agree 100% with everything you say. If the dumbass uses copper spray sealant, there is the smoking gun! I did run a professional machinists straight edge across all the decks, and surfaces.....I cannot slide a .0015 feeler under at any point. The deck and heads were 50RA surfaced and I'd say from the inspection of the machine work, its clean, neat and done correctly.
