HELP!!!
My bubble burst tonight..
Just idling in the driveway or driving around town it doesn't leak at all but when I started power braking it to about 5 psi several times I noticed a puddle of oil about 6" in diameter under the car!!!
WT*!!!!!!!!!!!!!!
I just put in a neoprene seal and it leaks under a small amount of boost only. I have the pcv plugged off and the v-covers have no breathers and are vented to the air so how can it be developing any crankcase pressure to blow oil out the rear main seal??????????? The rings??? The engine doesn't smoke at all but maybe that is the problem..?? I know the seal is in correct and I didn't see any worn spot on the crank.
It only leaks when power braking..
Does anybody have any ideas???? I can't go racing like this..
If I have to I'll drop the pan again or I'll pull the stupid motor. I am sick of these ***** oil leaks..
ks
WT*!!!!!!!!!!!!!!
ks
