HellOnWheels
HellOnWheels
- Feb 3, 2002
What should depict when a larger throttle body be used, turbo size, intercooler size, head flow, etc....
HOW
HOW
SignUp Now!Originally posted by BoostKillsStres
I don't think anyone's ever done back to back TB tests to see what if much is gained, at least not that I've ever read on the boards. ................r.
Originally posted by Nick Micale
Have known of 11 and 12 sec. cars not running as good with a 70mm as with stock TB.
Originally posted by Ormand
This only a 231 cubic inch engine. It does NOT need a throttle body as big as a BB chevy. No matter how much you raise the boost, it is still only 231 cubic inches, and the air flow is only going to be 400 cfm or so.
Originally posted by turbo2nr
You need to join us guys from VA/MD for the next track rental at Budds Creek. Talk to Red. I got 11.1 with that combo, stock block/heads/cam/suspension. I was happy with the little I have done.
It'll work great. Again, my Kenne-Bell 70mm. TB. installation netted a 2lb. increase in boost. Iwas controlling boost manualy. Back in 95'-96' Ken Duttweiler installed a Kenne-Bell 70mm. and upper plenum on a turbo Buick. At 13 lbs. of boost ,horsepower went up from 507 to 537. Torque went up from 528 to568. This motor did,however make 740 hp and 784 lbs./ft of torque at 25 lbs. of boost. The point is that even at 13 lbs. the stock throttle body was a restriction. When,in my earlier reply, I stated that the 70 mm. is the first thing any turbo regal needs,I ment to say that even a stocker,with an ample fuel supply, can bennefit from this. P.S. I wonder what would have happened if Duttweiler would have put the stock T.B. back on and pulled another dyno run?Originally posted by ws6formula50
I just bought that combo, TE61, polished 70mm TB, Precision plenum, RJC PP, hope it works ok with the 70mm, I wouldnt want to have to take it back off for a stocker
