SignUp Now!does anyone know where i can get new throttleshaft seals
i have a set for Free for you ! All you had to do is ask![]()
Seals, Seal, Gaskets, Metric, Oil, Hydraulic, Shaft, Mechanical, O-Ring, HARWAL
buick part # was 10x17x05B.![]()
Site says max pressure is 7 psi... You think it ever really gets there are a throttle shaft seal?![]()
Wish they had pics. I always thought they'd be semi-rigid.
You rock, thank you. I assume you are currently using these without issues?
I fat-fingered the keyboard above, was wondering if the pressure ever exceeds the holding ability of the seal at the shaft/seal area.
