I got my engine back from the machine shop a couple of days ago and noticed that the machinest had cut a V on the mateing flange on the thrust side of the bearing on both top and bottom halves. Has any body seen this before? I was planning to file the bottom bearing where it joins the top half of the complete bearing from the oil channel to the thrust surface. I'm not sure this would be a good idea the way it is now. The shop here in Houston has a good reputation for thir work. I just had'nt asked them about it yet. What do you guys think about what was done? Should I get another thrust bearing? Any input is always appreciated and I look foward to your replys. Thanks,
