I got word back, from my machinist, that my crank end play on my used standard high mileage TR crank is out of spec .012". I am the process of a second rebuild and purchased a used standard crank from a reputable list member. I had two center billet caps machined and installed and purchased 0.010" federal mogul performance wide bearings. My first question is are these bearings oversized for just the crank journals only? Do I need to specify I need 0.010" more on the thrust bearing surface as well? If so were is a good source to purchase a .010" bearing with the thrust oversized to .010"??
TIA
Mike Banas
87GN
TIA
Mike Banas
87GN
