I honestly can't believe that this "Mr Z28" guy would come on here and spread this crap. You'd think he'd at least hit an LS1 or LT1 board first for some reading to actually make his story sound real with a few possible combos to post about. I can't believe that anyone would come up with stuff like he did. I'd be surprised if he was even 16.
Now that I have a little more time to write I'll break down the lies one by one.
"i got fr rear end a 9" 3.27"
What is this? Were you trying to say FORD rear end? Nobody puts a 3.27 gear in a 9" for an LS1. 3.27 gears are for those Ausse 9-bolts that were stock in the late '80s TPI cars. Most that take the time/spend the money to put a 9" rear in an F-body get at least 3.73 gears. They come stock with a 3.23 option (2.73 standard) in autos and 3.42 in a 6-speed. Going to a 3.27 from those ratios makes no sense.
"..holley hood scope intake"
What's this even mean?
"Edlebrock Cam prformer RPM"
No Performer RPM kits exist for LS1s.
"holley carb.400 cfm"
Who would buy a 400cfm carb for a 346ci V8? Furthermore, I don't know of anyone that makes a carb intake that will bolt to LS1 heads/block.
"Edelbrock Heads (9.25)"
Again, these do not exist. No aftermarket head castings for LS1s. Edelbrock does not even machine stock LS1 heads. They have no LS1 head packages.
"eletrical system and everthing is basiclly stock"
So you're saying that you took a '95 (original LT1 car with OBDI) and converted it to an OBDII SEFI motor with coil-on-cylinder ignition and
then converted it to a carb setup with a stock LT1 PCM and stock wiring harness (you did say the car was a '95, so you didn't even start with an LS1 harness/PCM to begin with). That is not only impossible, it just sounds stupid.
".... i think i should go faste but im not i guess cuz it is a camaro..lol and not a GN"
The reason you're not going fast is cause this car is obviously a dream car, because that's the only place it could exist with that setup...IN YOUR DREAMS
Don't try and BS about LS1 stuff to me. I've had my hand in setting up quite a few of them in my club including my own. Everything from heads/cam packages, to blower and N2O setups, to custom tuning, tranny setups, full exhaust systems, suspension upgrades, etc. I've done A LOT with LS1s so you're not gonna be able to BS me any.
Sorry if it looks like I'm coming on too hard here guys...I just hate when posers like this guy make us LS1ers look bad by posting stuff like this on other car boards.
