Turbo Keith
TURBO KEITH
- Sep 16, 2015
Hello Guys , I have started hearing a " Ticking " sound that's in the front of the engine . As you rev the engine the ticking gets faster . I do not believe its an oil filter issue and I removed the belt to make sure it wasn't a bearing somewhere and it still ticks . The engine is stock , meaning the heads have never been off and stock bottom end . The timing belt is still stock also . Car has bout 75k miles . Thanks in advance Keith
I'm running alky , te61 , 60lbs and a front mount ic
