Ticking noise
tech1gmc
When the car is running I hear a ticking noise coming from the transmission. The noise follows the rpms, (it is hard to hear at higher rpms) and it happens in all of the gears, but the transmission works great.
got ticking also, but mine is in torque converter area. Goes away when i seperate converter from engine. :confused:
what do mean separate torque converter from engine? Also, do you think it could be the torque converter?
Could be a couple things...
1) Cracked pump rotor.
2) cracked converter neck.
3) bent or cracked flexplate
4) loose converter bolts.
My money is on number 1.
Ck all carefully.
Good luck
Bruce
We4
Performance Transmission Services
