Greetz people,
I have a fast ticking sound that occurs at idle in N or P and only when the trans/engine is hot. 200-4R
If I am correct the possible sources are:
1. Bolts - trans to flexplate are loose
2. Torque Conver hub crack (mine is a new one freshly installed... so unlikely ?)
3. Flexplate has crack around the crank bols (does that occur only when HOT ?!?!? - shouldn't it happen all the time then ?)
4. Rotor on the pump are broken - Since this noise only occurs when hot - I would think this would be the source.
Do I need a new pump ? Or can I DIY rebuild ?
MTIA
D.
MTIA
D.
