The Granny
- Apr 19, 2014
Yeah its going to be tuff Mike. This is one of the main reasons i pondered the x brace in the center. The X brace is not necessary for the 25.3 cert when you use the factory door hinge pillars. But if you modify the factory firewall and floor, or use fiberglass doors then the X brace is required. My car will not need the X brace, but i chose to do it just in case i ever opted for lighter doors.
When i studied the driveshaft layouts, in efforts to determining my ride height and pinion angle layouts, i studied whether or not it would come out. The drive shaft does come out, but it takes some work. The car will have to be high in the air, the rear end raised so the driveshaft can slide all the way out the rear of the car.
On another not all the control arm mounting points are not favorable for the instant center of gravity I think I need for the ride height I aiming for. I will get this all corrected.
Good progress! Not sure if you know, but baseline suspensions makes a bracket that bolts into the stock location of the upper control mount that has about 5 different possible locations to give you an adjustable instant center.
http://www.baselinesuspensions.com/kits/chevy.htm
