Time to purchase rods....
Chevota
Need some input. Think these will support some HP? :biggrin:
You are an animal! :eek:
So those are going to fit in the Supra engine:confused:
Got a spare rod aye what?
Just in case! :D Supra crank with hemi journals.. What more could you ask for? :eek: You're a good sport Don.
you might need a few more parts..
a block comes to mind!
them purty,
why is there only 4 of them, hmmmmm you gonna run a 4 cyl? ( yea I see 6)
Reply
Scott, anytime you can reduce reciprocating weight parts last longer & more power is available. I had a set of rods in the 350 TT project that I have been involved with forever. The engine held up very well with zero problems with the aluminum rods that were in it. I also noticed that the bearings were as new when ever I pulled it down for inspection. I attributed that to those rods & was impressed that when it came time to rebuild the engine. $1000.00 was invested in a set of GRP aluminum rods. I don't mean to disagree with any of the experts but I would call the manufacturer for their advise & go with that.
you guys are SO behind the times.
he building one 4 cyl and one 3 cyl. ( 3cyl like in a chev sprint)
rice is where its at.
with turbo for each cylinder .
scott didn't tell you guys? where working on a 3 cylinder prius motor hybrid turbo awd in a gt-four, alpine white on 16x10" rikens
jk ;)
You're ALL wrong...
It's a inline Volvo 5 cylinder:tongue: So, I've learned that if a steel rod breaks in an aluminum block windows appear.:D What happens if a aluminum rod breaks in a iron block? Any damage?:confused:
BTW - Thanks for the info Lou.
scott wile
Reply
scott wile
The only thing I can't ever remember is breaking a rod in a turbo engine. Everything else is another story .
if you want to get An** about it I see 7 Rods in the picture to be exact 6 in the box and the 1 on top. ;) he must have some sort of A51 SH** going on overthere.. :)
LOOK CLOSER. To the far left, the is the big end of the rods curve in the shadow. Then you can see the other 7 your "regular eye's" can see. My eyes are blue, yours are brown from all the doo doo coming out of your brain:D
good eyes,grasshopper (said in my best kung fu accent)
I don't see it, but then I don't see alot of stuff,
I do see a space where one should be.
volvo 5 cyl huh,? I claim BS!
its a mercedes 5 cyl, diesel conversion, with tripe turbos, and double intercoolers, with quad spark plugs per cyl,
its getting deep!
While Scott mumbles to himself, dang it! I should have just taken a picture of 4 rods. Dang it!
your smoking crack again, please put the pipe down whiteboy, there is only 7 in the picture unless you can prove there is another one there you should have your eyes checked, shadows dont count as rods.:biggrin:
wrong again knife boy!
look thru the pin end of the rod standing up... see the rod nut/ hole/ threads.. the nut to the 8th rod, ha hah ahaha ha ha ha
took me weeks to find it and I was in his garage, :eek:
its ok harold, were all gettin older,
