Tommorow I'm installing a new timing chain ,gears,water pump and hooking up a mechanical oil pressure guage.Can someone tell me if taking the drain plugs from either side of the block is a better way than risking antifreeze getting in the oil pan while removing the front cover. Also, when everything is back together can I unplug the orange ECM wire and roll the motor to prime the oil pressure (reading oil pressure guage).Will this work??? sorry 4 the long thread, I've been doing lots of reading but wasn''t sure.
Ron
Ron
