Timing cover crankshaft seal
Pwt1
I’m replacing the crankshaft seal on my timing chain cover It installs from the front (aftermarket). I removed the old seal and forgot which way it goes back in. Could someone post a pic on the correct way to install the new front seal. Thanks
You will have better luck getting a response if you post it below in the "Normal Threads" section. This section is supposed to be for instructional tips on how to do something.
