I'm looking for feedback on the engine gasket sets most of you are using when doing an engine rebuild. I have a leak from my front timing cover crank seal and want to know if it is better to use the fel-pro set (TCS45930) or to stick with using the gasket from the factory (GM). I know these engines are prone to leaks but I would like to reduce it by choosing the right gasket set.
thanks
thanks
