Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
This appears to be the TA1530C timing cover by TA performance. This was on my block when I picked it up before I had it machined and set up for my hot air setup. This timing cover looks brand new. The seals were still fresh and blue and clean when I removed it. The water pump feels and looks brand new and the adapter looks ok, will need a slight polishing. The gear pockets look great and there is no wear at all on the gears surface, nor on the ends of the gear to pocket surface. There is no play in the drive gear shaft and the drive gear shaft has no wear either. The cam sensor hole is clean and not worn either. The front seal even looks brand new. All together $200.00 for the complete outfit.
