Timing issue
blacknight80
Hey guys
I finally figured out my injector pulse problem and it's getting closer to running (after a year or more.....) but I can't seem to get the cam sensor in right. When I crank it acts like the timing is way off. It cranks easy a few times and then cough and back fires. I reinstalled it a few times but I'm getting sick of ripping off the coil pack to find out I did it wrong again. Could It be anything else? I have fuel and spark just at the wrong time. Thanks
Cam senser setting tool is a good investment. Did you use timing tape on the harmonic balancer? Are you sure your at top dead center on the compression stroke?
Ya I measured it out, stuck it to the balancer and drew it on with a paint marker. In pretty sure I'm at tds. I used a vac/compression gauge in plug 1. I rotate it until the compression turns into a vac. The factory mark on the balancer lines up with 0 deg. I think that's right isn't it? I used a voltmeter and back probed the cs weather pack and get 6.95 volts. I rotate it clockwise until it drops to zero and lock it in. I don't get anything lower than .33 volts at the lowest point though. I tried two caps one used and one brand new.
You turn counterclockwise till it drops. You're on the wrong side of the window
It should only be 0 volts once per rotation right? Without turning the crank that is.
It's zero at the window. You are on the wrong side of the window
Is my drawing how it works? If that the case would it matter where you drop the body in? Would it only matter where the cap is located on the reluctor?
O I got you so I want to make sure the cap starts counter clockwise from the window and turn it clockwise towards the window until the voltage drops?
The position of the window relative cap if the crank is in the right spot. Which is 25* atdc compression. So it's actually in the power stroke. It's not even a precise setting. You can be off buy several degrees with no effect.
Ok I'm pretty sure I'm 25 atdc. I seen two different sets of instructions to install one said have the dot on the gear point towards the ps fender and the other said have it point at 3 o'clock if you were looking from the front. These is irrelevant then? As long as the I have the cap in the right spot (0 volts)? Thanks for your patience I'm a carb distributor kind of guy lol.
Sent from my SM-G900W8 using Tapatalk
Re-read my post about the wrong side of the window. Think carefully about this. The entire window is zero volts.
I'm picking up what your putting down now. Thanks.
I reset it again amd it's a little smoother cranking. Here's a few videos of what it's doing. The battery got a little weak towards the end.
If that's an aftermarket cap you need to follow the instructions that go with it!
I don't have any instructions. One cap was on the sensor and the other came in a blue plastic package with the rest of the 85 parts to do the swap. I'm fairly confident i have the cam sensor set correctly. I followed a good video on YouTube and triple checked it. These are basic caps with no lights on them. If a cap has failed does it die completely? Thanks again for the continued help you have no idea how much I appreciate it.
If using a standard cap and get to the edge of the window while turning counterclockwise at 25* atdc compression then you should have success every time. If a stock dimension balancer then the mark needs to trail the timing mark about 1.45". Setting this easy gets the cam sync around 80 degrees and works every time.
If you're sure the cam sensor is correct then you have the firing order wrong
I've got type ii ignition I better have a look at it tonight and check my plug wires. Measured 1.45 and marked it on the stock balancer counter clockwise from the stock mark.
I also heard you can ruin the ignition cranking the engine with a plug out to check for spark . Thats if the spark plug isnt grounded properly. Maybe someone could verify this.
