timing question
1QWKPHKR
B & B RACING TUSCALOOSA A
my car @ idol has a 36.5+ degrees timing. and under acc. it gets up to around 56.4+ degrees . i have a jay carter super street 93 chip .. and as i stated in an earlier post my car starts to build boost at about 4000 rpm it studders like it is running out of gas .. ive changed everything...crank , cam ,sencer fuel pressure reg, plugs , wires , coil pack and module, esc control , computer , tps ,injectors, fuel pump, filter water temp sencer mass air sencer barometric air sencer.. hell i dont even know what eles :mad:
thanks for any help guys ...buddy
Not sure what Jay does with his chips these days so I don't know if the 56 degs you are seeing means anything or not.
It sounds like the car is detonating and getting ready to blow a head gasket or make you a member of the dotc club.
I would suggest you contact Jay and talk to him about your symptoms. I would keep my foot out of it until I knew what was happening tho.
How much retard, if any, does your scan tool show?
