- May 28, 2001
GN/S-10 from Hell!!
Russ, I think there's a clue in that it's backfiring out the tailpipe.
That tells me there's fire to the plugs, there's fuel from the inj's.
If it's firing out the exhaust, then there's only 2 things that cause that.
1. Lighting the fire at the wrong time.. IE: the exhaust valve on one of 2 cylinders is open.[Waste fire system] Wrong valve timing.
2. The valve timing is right, but the ignition timing is not.
Vapors from the crankcase by just cranking the engine cold is not normal!!
If you have changed modules or coils, did you hook the wires up to the underside of the coil correctly???
A dumb ? on my part. Does the FP prime and then shut off?? What does the PSI go to when you turn the key and the pump starts? Does it stay there or close when you go to the start position? Have you tried to jump the pump to stay on ?
Could be the psi is falling and the inj's are not operating like they should....?? Just a guess
