72firebird
- May 18, 2004
I know that we've had these before but I have noticed a lot of new people and therefor more useful inputs. I think a lot of us are not only into going fast but also looking good. So post little tricks you have found to keep your TTA looking good or just good for the show. Anyways heres the tricks I have learned over the last year that I have owned my TTA.
1. Set all hose clamps facing the same way in the same position (screw part up and to the left is what I use and then the MAF pipe I use up and foward)
2. Wheels are a big exterior appearance feature. TTA wheels are hard to keep clean and looking good. For the center just use water and cuetips for the centers. It's time consuming but you'll understand why when you're done.
3. Adding more for the wheels, try the new power ball from Mothers and some NXT wax or your preference on the lip. It'll bring the shine back but if you have imperfections in them they'll stand out more. I just did this a few weeks ago and liked the results. I also made a cardboard piece to fit down in the wheel to cover the gold part.
4. Final for the wheels, the center cap turns. Small small detail but makes a big difference turn the cap so you can read the WS6.
5. Clean windows helps make a car stand out. Now smears or finger prints shows the interior better.
6. Under the hood I started to disassemble pieces such as the parking lights and cleaned and waxed the black piece and got down on the frame rail on the passenger side. If you do this once and just keep it mantained it'll stay looking good.
7. For those now going for the stock look using some steel wool on the steel lines for AC, fuel, and coolant ot bring them to a shine is a nice touch. I use Wizard products to keep them shinning. Just step down through the steel wools until you get the shine desired. Little time is necessary to do this. I think I did all my line in like 4 hours. If you have time you can try the AC condesnor but it requi=res more mantaince.
8. The inner fender liners get dirty easily. I used a little purple power that I diluted a little with water then sprayed them down and wiped it off.
Those are all I can think of right now. Post up your suggestions and help the rest of us out.
