tips on alky setup and tuning
dank GN
BlackArts Automotive (661)993-8277
I was woundring if there is any tips u guys can give about install and tuning?
Read the Instructions COMPLETELY
Take your time. Double check everything. do you have a power logger or a wideband?
Start on the rich side to be safe. Its easy to use the search function from minor problems and Julio is a top class dude. Erics support is great too. You should be good to go without and issues. Don't get greedy too fast.;)
I have a scanmaster 38lb injecters k&n and a 3" all the way back from turbo
Keep an eye on your scanmaster for retard, and start on the rich side like jaz said. Who's kit did you get? Stuff works. I'm still running old non-progressive. Getting 23-24 psi no knock. I'd like to get the newer progressive some day. Good luck with it.
The razors kit is on it's way. I have a little knock now like anywhere from 1 to 4 @ tra sition to 17lbs of boost I am hoping this kit will cure that
Ohhhhh it WILL :biggrin: I've had Julio's kit on for about a month now. Work's awsome.
One of the first kit's ever sold and I can't count the amount of gal. of alky I've used, WHATS RACE GAS!!!!!!
you won't be disappointed!!!!!
JD
JD
How many gallons of meth have you gone through :eek:
:D
