Tampa T-Type
- Jul 17, 2005
Need new rubber I now have (235-60R-15) what can I fit under my car?
Do I need the replace the rims is so what options do I have for size for the rear. The car is at the end of a big modifacation and I'm afraid of to much power and too little wheel. Any links wouls be helpfull!
Second request!
1985 Buick T-Type
1987 ECU
Spearco Intercooler Part # 2-135
Turbo Turbonetics, Cheeta .63
Adj Wastegate
GReddy Profec B2
Kenny Bell Headers
Kenny Bell Air and breather filters
Fuel pump 340
Hot wire kit
Razor Alki running meth
Chip Thrasher 93
K&B dual stage headers with down pipe
3” High Flow cat converter
2 ½ dual mandrel exhaust
MSD 50 Lb injectors
Lt-1 Maf
Translator
Bgc Adj fuel pressure regulator
2004R Shift kit rebuilt with all new performance parts
2800 Torque Converter
AVC Motor Sports GNX cluster dash kit analog
30 Lb boost gauge
Oil pressure
Temp Gauge
New cam “cams 231t 0.519”
New crankshaft 0.646
Valve springs
V-8 Radiator
Rod and main bearings
Oil pressure booster plate
Throttle enhancer
Turbo ram air not installed
Second request!
1985 Buick T-Type
1987 ECU
Adj Wastegate
GReddy Profec B2
Kenny Bell Headers
Fuel pump 340
Hot wire kit
Chip Thrasher 93
MSD 50 Lb injectors
Lt-1 Maf
Translator
30 Lb boost gauge
Oil pressure
Temp Gauge
Valve springs
V-8 Radiator
Throttle enhancer
