regal81455
- Oct 20, 2008
X2 on the sticky!
SignUp Now!That's just simply insane. I hope you can get everything worked out.
I've got a question for people in the know. Do T wheels & GTA wheels also need to be mounted from the back side of the rim as well?
no they get done like any other rim , face up
but you have to watch with the gta rims and some balance machines that the cone they use doesnt break away the thin lip for the caps , this is a common problem on the dimpled GTA rim,, used to be a concern on the old coats 2020 tire machines but no one uses those anymore since they were only good for 15" and smaller rims , almost everyone is using the overhead tire machines
Its like nobody ever heard of a reverse rim, what a bunch of idiots, you definitely found the biggest idiot out there, AND watched him do it to all of your rims LOL... Who are you going to take it to for the oil change?
Anyone knows when you disbead a tire, you always look at the drop down center of the wheel.
Look what I found when I got home today:
Here are the rest of the pics of the bends. The last two are the worst.
The drop center is the lowest point of the inside portion of the wheel. The center section sometimes depending how the wheels is made. The shortest distance to the outside part of the wheel needs to be facing up.
4 years experience and you are claining NEVER? my father has been in the business for 40 years. He has an old style tire maching at his shop and has done up to 19 inch wheels on his ancient machine. When we mounted my set of NOS eagle GT's on my stock Olds Rallys we needed to use a pry bar slightly. sometimes the machine cant spin the bar that installs the bead...and you beat the sidewall with a hammer or pry it down. You are never prying on the wheel thou, the inner rim is just your anchor point for leverage. you put the tip of the pry bar in there and use the shaft of the pry bar to press down on the sidewall till the install bar can spin all the way around the rim. we've never had a problem...EVER... never broken a bead, never bent a rim... its people who do not know what they hell they are doing or people that think they know what they are doing because that passed an ase test or some crappy trade school.I worked tires for four years, and I did do tires on more than a few GNs (along with many other specialty cars). There should never be any need to use a pry bar on a steel 15" Buick wheel, especially with a tire with a sidewall as soft as a Radial TA.
