I need to roll the lips. When my car was stolen and treated like it was the General Lee, the sides of the tires were cut and shaved all to hell. Keep in mind, I moved my centerline when I had mine done. The widened wheels that are available now put the entire inch on the outside of the rim.
I went through a lot of trouble making sure my axle was dead nuts centered on the frame and my body is dead nuts centered on the frame. Alum drums also got me another 1/8" of clearance. If any of those are out of whack, you'll probable end up rubbing, cutting, or having one wheel stick out past the lip while the other doesn't.
Tru Design did the job back when it was cost effective to get them done.
The only bad part is the chrome the use on the new hoops is absolute shit. They started forming rust bubbles almost on day one and started breaking through in about a month or two. While my car sat while I was putting it back together the bead area on the lowermost part completely flaked off from rust.
