I did a lot of research on running Ti valves before I decided to run Ti for both intake and exhaust.
First off, in a boosted situation, especially with high exhaust back pressure to intake boost pressure ratios, the exhaust valve will be the first valve to look at for floating at high rpm limits, even though the exhaust is lighter than the intake.
Even in my situation where my exhaust back pressure to intake boost pressure ratio is very favorable, the exhaust valve will still be the valve to float before the intake.
