I *FINALLY* got to the track after 3 years of prepping the car and fixing little things here and there. This is with v3.0.2. I had a TPS trigger set, but being nervous and new to using TLink at the track, I also hit the spacebar right before staging - I wanted to make sure it was recording. After the run, I saw the error msg [Connection to the ECM has been lost]. The disconnect seemed to occur right around the time the TPS trigger would have fired. Did the trigger fire only to find that TLink was already recording and say, "forget it, buddy?"
Thanks for any help.
