I'm slowly making progress on my 84 upgrade. Should have it running soon. Still need to hook up all vacuum lines, some wiring, racegate and other misc. things.
If you take a look at the up pipe you'll notice it looks a little different. I had to add about 7/8" vertically so it would line up good with the PT54 (this turbo has to sit higher due to the taller compressor housing). There is not a lot of hood clearance left.
Check out the engine mounts, they were all bad. The drivers side was completely separated.
What do you think of the custom TS air filter at the turbo?
Let see if this works
