I am installing my system sometime soon...(2 amp set-up/dual sub kicker etc..) and wanted to know if anyone has a trick to running the big red power wire from battery back into the trunk.  There was a trick I used with my IROC where I was able to effortlessly run the wire from the engine compartment to the door and then just cut into the rubber wire housing and used that to get into the car itself and behind the dash.  Then I just ran all of my wires (speaker wires, aux wires, blue amp wires etc.) back into the "trunk".  Now I know that the IROC was easier because of all the plastic moldings inside where I could just run and hide the wires and since the Camaro is all open, the wires ran nicely to the back due to the hatch set-up.
With the GN, I guess I gotta pull the back seats to run the wires?
Do I have to pull the carpet to hide the wires or is there another way? Can I use the metal foot runner?
Do I have to drill into the firewall to run the power wire into the car?
I appreciate any imput as to how you tackled the job...before I rip things apart that are not necessary!
